| Work with Renewable Energy? https://brainfiller.com/arcflashforum/viewtopic.php?f=33&t=5543 |
Page 1 of 1 |
| Author: | Jim Phillips (brainfiller) [ Sun Jan 30, 2022 2:37 pm ] |
| Post subject: | Work with Renewable Energy? |
I am at an IEEE meeting this weekend and had a long discussion about renewable energy systems and safety. That prompted this week's question. Have you worked with renewable energy systems? What types? Select all that apply. None Solar Wind Geothermal Biomas Hydro Tidal/Ocean Other - Specify |
| Author: | Larry Stutts [ Thu Feb 10, 2022 9:53 pm ] |
| Post subject: | Re: Work with Renewable Energy? |
I worked specifically on a solar inverter, but the inverter was supposed to do wind and tidal as well. It also was able to use battery power as well. |
| Author: | Doug Powell [ Mon Oct 03, 2022 12:11 pm ] |
Jim Phillips (brainfiller) wrote: I am at an IEEE meeting this weekend and had a long discussion about renewable energy systems and safety. That prompted this week's question. Have you worked with renewable energy systems? What types? Select all that apply. Yes, with several types: Photovoltaics and Energy Storage: Lithium Battery, Flow Battery, Flywheel, Thermal. All this from residential to utility-scale installations. ~doug |
| Author: | SamoKablamo [ Fri Oct 21, 2022 7:17 pm ] |
Not sure if this counts as renewable, but I worked on a downhill conveyor that regenerated power by a VFD. |
| Author: | Doug Powell [ Mon Oct 24, 2022 10:01 am ] |
SamoKablamo wrote: Not sure if this counts as renewable, but I worked on a downhill conveyor that regenerated power by a VFD. I would think a regenerative downhill belt conveyor would not necessarily be a renewable energy source. We see this sort of thing in EV regenerative braking as well. I believe this would mainly fall under the heading of system efficiency. Plus the electrical safety aspects should be well covered by VFD safety standard, I should think. ~Doug |
| Author: | charlesdean [ Wed Oct 07, 2026 9:02 pm ] |
When it comes to renewable energy, electric vehicles and solar panels immediately come to mind, yet I have significant concerns regarding the stability and sustainability of these forms of energy. |
