Suspension fault on my L405 and I'm too scared to take it ju
https://brainfiller.com/arcflashforum/viewtopic.php?f=2&t=6426
Author:  willowwatson [ Mon Apr 13, 2026 6:16 am ]
Post subject:  Suspension fault on my L405 and I'm too scared to take it ju
Alright so my 2016 full size RR decided to throw the dreaded "suspension fault normal height only" message on the dash this morning right as I was pulling out near Corniche and the front passenger corner is now sitting just a touch lower than the rest of the car after parking it for a few hours. I've had the thing for three years and I knew this day was coming because we all know the air struts on these British trucks are basically a consumable item out here in the heat and humidity but I'm really trying to avoid the main dealer diagnostic fee that just gets you a quote for replacing every single component in the system. I need someone who actually knows the difference between a simple valve block leak and a compressor on its last legs without throwing parts at it, you know the kind of shop where they actually rebuild the strut instead of just selling you a new one for the price of a small used Japanese car. I keep seeing the phrase Range Rover Expert Repair Abu Dhabi pop up in my searches and I'm curious if anyone has a real solid indie garage they trust with the air suspension specifically because I'm not trying to have a perfectly good compressor burned out by a bad leak diagnosis. Any names or places in Mussafah you guys would let touch your own L405 would be a lifesaver right about now.
