It is currently Mon Oct 12, 2026 7:13 am
 Post subject: Dependence of IE and I
PostPosted: Tue May 19, 2020 3:25 am
The thermal energy in a fault is proportional to I^2 t. But the IE result for any arc flash study always shows7 that the IE is proportional to I. I am very curious why is there such an anomaly.
 Post subject: Re: Dependence of IE and I
PostPosted: Tue May 19, 2020 9:40 am
There are many factors that come into play regarding incident energy. First let’s define the term incident energy. According to 2018 IEEE 1584, Incident Energy is defined as:
“The amount of thermal energy impressed on a surface, a certain distance from the source, generated during an electric arc event.�
This means that the incident energy is not the total energy at the arc flash based sole on the current and time as in I^2. It is the energy that travels from the event towards a surface (worker) which means a few things such as.
-Not all of the thermal energy from the arc flash reaches the worker
-The energy dramatically decreases with distance from the arc flash
-The rate of decrease depends on the enclosure, opening size, voltage, electrode orientation and many other factors.
I hope this helps your understanding. Feel free to check back in if you have any other questions. Lots’ of people here ready to help.
