| NFPA 70E-2018 Adoption https://brainfiller.com/arcflashforum/viewtopic.php?f=7&t=4442 |
Page 1 of 1 |
| Author: | BGnan [ Sat Sep 23, 2017 6:15 am ] |
| Post subject: | NFPA 70E-2018 Adoption |
When does 2018 Edition of NFPA 70E get adopted/go into effect and replace the 2015 editiion? What organization(s) do the adopting of a new edition? Thank you! |
| Author: | PaulEngr [ Sat Sep 23, 2017 7:25 pm ] |
| Post subject: | Re: NFPA 70E-2018 Adoption |
BGnan wrote: When does 2018 Edition of NFPA 70E get adopted/go into effect and replace the 2015 editiion? What organization(s) do the adopting of a new edition? Thank you! Well, it's the 2018 edition to obviously the date matters. 70E is not "mandatory" per se. It is voluntary. It is referenced by other standards such as NEC (NFPA 70) which gets updated on a three year cycle too but it is one year behind 70E so it won't get updated until the end of 2018 (2019 edition), so this should spread the adoption rate by other standards over a three year period. As to the regulatory/mandatory nature, OSHA uses 70E (not any particular edition) as a reference document for arc flash incidents if the company doesn't have any sort of standard, but there are competing standards that could be used |
| Author: | BGnan [ Mon Sep 25, 2017 3:06 pm ] |
Thank you! |
| Author: | Robertefuhr [ Mon Oct 02, 2017 11:57 am ] |
I always understood that NFPA 70E effective on January 1st of the Year that is in the Title. So, NFPA-70E would become effective 1/1/2018. |
