| Handbook? https://brainfiller.com/arcflashforum/viewtopic.php?f=7&t=4415 |
Page 1 of 1 |
| Author: | uriah1 [ Thu Aug 24, 2017 5:41 am ] |
| Post subject: | Handbook? |
Do you typically purchase the NFPA70E handbook along with the standard? Or just the standard ? Or just the handbook ? Thanks! |
| Author: | wbd [ Thu Aug 24, 2017 7:10 am ] |
| Post subject: | Re: Handbook? |
I usually purchase just the standard. There was a question of the week regarding the handbook. https://brainfiller.com/arcflashforum/viewtopic.php?f=33&t=3448&hilit=handbook |
| Author: | PaulEngr [ Thu Aug 24, 2017 8:15 pm ] |
The handbook includes the text of the standard. With 70E it's not terribly helpful. With 70 (NEC) it's almost a must and I always get the handbook version. NEC contains a lot of interwoven requirements and the handbook helps in referring to other sections as well as containing a lot of "this is what we really mean" explanations. |
| Author: | Oly [ Wed Aug 30, 2017 8:41 am ] |
I have found that the 2014 NEC 70 2014 handbook in pdf was constructed with hot links that allow one to "pick & jump" to a sited reference. This is an immensely efficient feature. The 2017 NEC 70 standard text pdf (non handbook) does not have this feature and I have found it to be a boat anchor in comparison to the 2014 handbook. I have confirmed with NFPA sales that both pdf versions of NEC 70 and 70E handbooks have this "pick and jump" reference feature; the standard pdf volumes do not. |
