| Capacitive test points - phasing https://brainfiller.com/arcflashforum/viewtopic.php?f=5&t=6054 |
Page 1 of 1 |
| Author: | egabe1 [ Thu Apr 24, 2025 6:28 am ] |
| Post subject: | Capacitive test points - phasing |
We are looking to hot phase between two 15kV cables. These cables have Tyco elbows installed on the ends of them which include a capacitive voltage test point. When using these test points, what kind of safety precautions need to be made? |
| Author: | mpparent [ Fri Apr 25, 2025 7:58 am ] |
| Post subject: | Re: Capacitive test points - phasing |
Use a hot stick / shotgun to take them off. Then you can use your proximity tester (attached to a hot stick / shotgun) to test for 0 volts. Mike |
