| Arc Flash and Tie Failure https://brainfiller.com/arcflashforum/viewtopic.php?f=33&t=5337 |
Page 1 of 1 |
| Author: | Jim Phillips (brainfiller) [ Sun Jul 19, 2020 12:58 pm ] |
| Post subject: | Arc Flash and Tie Failure |
Here is an interesting question. When modeling a main-tie-main a.k.a. double ended substation where only 2 devices are closed at the same time, would you consider an arc flash at the tie being fed from both sides in the event that the tie fails? Main-Tie-Main For arc flash, do you consider a tie to be fed from both sides in the event it fails Yes No Depends Curious about opinions. |
