| Barricades per NFPA 70E 130.7(E)(2) https://brainfiller.com/arcflashforum/viewtopic.php?f=33&t=2364 |
Page 1 of 1 |
| Author: | Jim Phillips (brainfiller) [ Sun Jul 29, 2012 11:43 am ] |
| Post subject: | Barricades per NFPA 70E 130.7(E)(2) |
Section 130.7(E)(2) of NFPA 70E states: "Barricades shall be used in conjunction with safety signs where it is necessary to prevent or limit employee access to work areas containing energized conductors or circuit parts" This week's question: What type of barricades do you use to restrict access to work areas? (select all that apply)
| Author: | mvan [ Wed Aug 01, 2012 3:54 pm ] |
| Post subject: | |
most of our mcc's and substations are out in the plant, we do not have electrical rooms, so when we are doing electrical work we are in high traffic areas. so we bought retractable 25 ' caution tape, mounted magnets on back of unit so we can move them as needed and they are kept on our remote racking cart. for storage and easy access. |
| Author: | Gary B [ Mon Sep 24, 2012 7:21 pm ] |
| Post subject: | |
Voted all of the above because cones, tape and limited access are all used. However, this is on a controlled site, with not access by the public, and well acquainted with radioactive NDE work so barrier tape gets a lot of respect. |
