It is currently Fri May 01, 2026 5:46 pm
 Post subject: Recommended Arc Flash Suit
PostPosted: Fri Feb 28, 2025 6:41 pm
I need a 40 cal/cm² arc flash suit for live work on 13.8 kV switchgear in an indoor substation. Focus on comfort and full-body protection is a plus. What brand or specific suits do you recommmend for this level of protection?
 Post subject: Re: Recommended Arc Flash Suit
PostPosted: Mon Mar 03, 2025 3:47 pm
I can't recommend but do a web search, due diligence etc. Be sure it complies with either ASTM or IEC standards. See where it is made, some counterfeit PPE is out there.
PostPosted: Tue Oct 14, 2025 8:52 pm
Go with a well-known NFPA-70E / CAT-4 (≥40 cal/cm²) kit from a major vendor that advertises lightweight / breathable fabrics and a good hood option (lift-front or PrismShield) for comfort and full-body protection. Strong candidates are below with why I’d pick them. Try before you buy if possible — fit/mobility matters a lot for live switchgear work; many vendors/distributors will demo or exchange.
Geometry Dash
PostPosted: Thu Dec 04, 2025 12:48 am
That's a serious protection level! For 40 cal suits, consider brands like Salisbury or Oberon. Look for multi-layer systems with breathable fabrics for comfort in the substation. Ensure full head-to-toe coverage, including gloves and hood. I'd also suggest playing Block Blast during breaks to de-stress. Great post!
PostPosted: Thu Mar 26, 2026 1:29 am
That's serious protection you need! Comfort is key when working around that voltage. I've heard good things about Salisbury and Oberon suits for that level of protection. Also, consider weight distribution accessories to reduce fatigue. Speaking of relaxing after a tough day, have you ever tried the Suika Game? It's surprisingly addictive fun – a great way to unwind. Might not protect you from arc flashes, but it will ease your stress!
PostPosted: Fri Apr 03, 2026 12:25 am
Finding the right arc flash suit is crucial for safety. A 40 cal/cm² rating for 13.8 kV gear demands serious protection. Consider brands like Salisbury or Oberon, known for their quality. Comfort matters too, especially for long tasks. Think about features offering better mobility. Perhaps choosing your best Pips NYT score is less stressful than this decision! Full body coverage is a must-have. Prioritize independent testing and certifications.
PostPosted: Fri Apr 03, 2026 1:38 am
Hey Jolabebe67, that's a serious level of protection you need! For comfort with that high cal rating, I've heard good things about Salisbury and Oberon. Look for suits with integrated ventilation – makes a huge difference. Also, check the user reviews; sometimes you get a sense of real-world wear and tear. It’s something the Football Bros at my work always emphasize - gear that really holds up under pressure. Good luck finding the right one! Safety first!
PostPosted: Thu Apr 16, 2026 2:41 am
Okay, so 40 cal/cm² – that's serious business for 13.8 kV, indeed! Finding something comfy enough to actually work in is key. Indoor substation? Think claustrophobic! Speaking of heat, I once had to troubleshoot a fried control panel and felt like I was inside a toaster. It was intense, like playing Slither io but with real fire. I recommend looking at Salisbury or Oberon; they often balance protection and ergonomics well. Think about cooling systems if you are doing extended work periods too. That heat can become unbearable.
