| Red Danger Label Printing Service? https://brainfiller.com/arcflashforum/viewtopic.php?f=24&t=1377 |
Page 1 of 1 |
| Author: | deprico [ Wed Nov 03, 2010 7:14 am ] |
| Post subject: | Red Danger Label Printing Service? |
I have been unable to find a label printing service that will print the red danger labels on the industrial grade vinyl. ESA will print the orange warnign labels only. Has anyone found someone who can provide me with the red danger labels? |
| Author: | wbd [ Wed Nov 03, 2010 7:20 am ] |
| Post subject: | |
Hi, I have used a local printing service. They can take the spreadsheet and put the information on a label with header colors and wording of your choice. Have you tried your local print services? |
| Author: | Robertefuhr [ Thu Nov 04, 2010 4:25 pm ] |
| Post subject: | |
You may want to look at getting a Duralable Pro label machine. They will print labels on a variety of colors. We have been using them for a number of years are happy with the machine plus they have great customer service. |
| Author: | ChevsMark [ Mon Nov 08, 2010 8:40 am ] |
| Post subject: | |
[font="Comic Sans MS"][SIZE="3"]Try Brady. They make a number of different labels. Or if you have a lot of labels to make, consider buying a Brady Printer/Label Maker and design your own. I use the Power Mark Sign and Label Maker #135000. You can buy different label widths and different ribbons for a large variety of size and color selection, and the label material is vinyl. The labels are for a variety of environments.[/size][/font] |
| Author: | jack23 [ Fri Jul 21, 2017 3:06 am ] |
| Post subject: | Re: |
wbd wrote: Hi, I have used a local printing service. They can take the spreadsheet and put the information on a label with header colors and wording of your choice. Have you tried your local print services? Hello there, I don't want to use any printing services because they are very costly. Thanks |
| Author: | arcad [ Fri Jul 21, 2017 7:45 am ] |
| Post subject: | Re: Red Danger Label Printing Service? |
deprico wrote: I have been unable to find a label printing service that will print the red danger labels on the industrial grade vinyl. ESA will print the orange warnign labels only. Has anyone found someone who can provide me with the red danger labels? <deleted link to commercial website for service> |
| Author: | henrick45 [ Mon Aug 20, 2018 10:34 pm ] |
Hello Can anybody tell me is this red label printing service is beneficial for me or not? because I used a local printing service and it takes lots of time. Thanks in advance |
| Author: | PaulEngr [ Tue Aug 21, 2018 3:14 am ] |
henrick45 wrote: Hello Can anybody tell me is this red label printing service is beneficial for me or not? because I used a local printing service and it takes lots of time. Thanks in advance If you can do it all single color why not? The "danger" label is incorrect by standards anyway and despite what the software companies were doing, it's an ANSI 535 violation. All arc flash labels should be warning, not danger. They were printing "no safe PPE" for 41 or higher cal/cm2 based on a misinterpretation of a note about 40 cal/cm2 in 70E that was inserted in the 2000 edition to encourage deenergization, then removed in the 2018 edition because the rest of the text had advanced beyond that point. |
| Author: | jack44 [ Thu Oct 04, 2018 10:28 pm ] |
Hello, Is anyone who tells me where to go for label printing? I need this services immediately. Thanks in Advance |
