| ATS Short-Circuit Ratings https://brainfiller.com/arcflashforum/viewtopic.php?f=23&t=6391 |
Page 1 of 1 |
| Author: | bunkst [ Fri Jan 16, 2026 1:33 pm ] |
| Post subject: | ATS Short-Circuit Ratings |
Hello all! I'm a new forum member, but I've lurked for a long time and I've taken a few of Jim's classes, so I'm not entirely a stranger. I have some questions about ATS short-circuit ratings that I can't find clear answers to anywhere else. But there are some pretty smart people around here, so I have high hopes. I do have a particular situation I need a solution to, but I've phrased my questions broadly to try to get a complete answer. Here goes: This is my understanding: If we are using the any-breaker time-based rating of an ATS, I have understood that both the fault current and the clearing time must be below the values in the WCR table. So, for an ATS that has a time-based rating of 42kA and 0.05 seconds, the fault must be below 42kA and it must clear within 0.05 seconds. Is that understanding accurate? If that is accurate, then a follow-up: an ATS may have short-time ratings where it can withstand a lower fault for a longer duration. For example, an ATS may have a short-time rating of 7500A for 0.2 seconds. Same deal: we must show that both the fault current and the clearing time is less than the rated values. Is that understanding accurate? Assuming I'm understanding that accurately, here are my questions that I can’t find clear answers to:
I really appreciate y'all's time and help! |
| Author: | bbaumer [ Fri Jan 16, 2026 3:05 pm ] |
| Post subject: | Re: ATS Short-Circuit Ratings |
This document may help: WCR-ATS_Pub-1128-R37.pdf https://share.google/MJ0V0xPCOyonBvSev |
| Author: | bunkst [ Mon Jan 19, 2026 6:31 am ] |
Thank you for your reply! I have reviewed that document, as well as a few other manufacturer white papers and they do not answer the specific questions I posed. |
| Author: | JBD [ Tue Jan 20, 2026 2:44 pm ] |
I believe all of the the WCR is based on short circuits, which means they occur in the instantaneous region of the OCPD. The use of specific protection devices, both fuses and breakers does mean you do not need to do any further analysis. The ATS is protected by these tested devices. |
