| OSHA 1910.269(l)(8)(ii) arc flash calculation 2015 deadline https://brainfiller.com/arcflashforum/viewtopic.php?f=22&t=3546 |
Page 1 of 1 |
| Author: | ekalbs4 [ Fri Nov 21, 2014 1:18 pm ] |
| Post subject: | OSHA 1910.269(l)(8)(ii) arc flash calculation 2015 deadline |
Is the intent of OSHA for the "reasonable estimates of incident energy" to be completed by 1/1/2015 or to "commence" as of 1/1/15 and to have completed in such a time that by 4/1/15 the employer's clothing program is up and running, based on the calculations. Is it okay if I'm still working on the estimates after 1/1/2015, or must I be completed? |
| Author: | wbd [ Sun Nov 23, 2014 7:45 am ] |
| Post subject: | Re: OSHA 1910.269(l)(8)(ii) arc flash calculation 2015 deadl |
I believe that the use of the term "commences" indicates that is when OSHA expects employers to have made a reasonable estimate of the IE as per 1910.269(l)(8)(ii). In other words, if an OSHA inspector shows up at your door after Jan 1, 2015, you are expected to have a reasonable estimate of IE done. |
| Author: | rdj [ Mon Nov 24, 2014 8:10 am ] |
OSHA intends for it to be competed, but has delayed enforcement until August. |
