| OSHA SubPart S https://brainfiller.com/arcflashforum/viewtopic.php?f=22&t=106 |
Page 1 of 1 |
| Author: | ARC_Dave [ Fri Apr 11, 2008 7:17 am ] |
| Post subject: | OSHA SubPart S |
Here's a good one.... I just read on the website for The Workplace Safety Awareness Council that the August 2007 Revision on the 29CFR1910.301-.399 requires arc flash hazard boundaries, equipment labeling and PPE. Can anyone confrim this? I am trying to find a place to purchase the standard, but so far I can't find a place to do that. The above mentioned website is linked below. http://www.wpsac.org |
| Author: | Yoda [ Wed May 21, 2008 9:02 am ] |
| Post subject: | |
That would be an earth shaker. If you find this, please post it here. Thanks! |
| Author: | Zog [ Mon Jun 02, 2008 8:55 pm ] |
| Post subject: | |
PDS_Dave wrote: Here's a good one....
I just read on the website for The Workplace Safety Awareness Council that the August 2007 Revision on the 29CFR1910.301-.399 requires arc flash hazard boundaries, equipment labeling and PPE. Can anyone confrim this? I am trying to find a place to purchase the standard, but so far I can't find a place to do that. The above mentioned website is linked below. http://www.wpsac.org You were misinformed (Too bad ti should be) the Aug revision adopted the installation section of the 70E, not the safe work practices, that is coming soon, I heard Feb 2008 but we are way past that already. |
| Author: | MJones [ Thu Jun 12, 2008 7:06 am ] |
| Post subject: | |
You can get PDF's of specific CFR sections via this website: http://www.gpoaccess.gov/cfr/retrieve.html Also, here is a link to the 2005 Federal Register where OSHA proposed changes to it's utility standard 1910.269 to add arc flash requirements: http://frwebgate.access.gpo.gov/cgi-bin/getpage.cgi?dbname=2005_register&position=all&page=34866 To my knowledge, these changes have not been adopted into 1910.269. I bet they are still being litigated. |
| Author: | HarryJohon [ Wed Dec 24, 2014 12:15 am ] |
| Post subject: | Re: OSHA SubPart S |
It seems 1EEE 1584 provides guidance in cutting off calculations at 2.0 seconds of arc exposure. I provide training as such and caution the workers that for certain job tasks/approaches this assumed time constraint may not be valid. |
