Easy Power Printing
https://brainfiller.com/arcflashforum/viewtopic.php?f=15&t=2642
Author:  Tim O [ Mon Feb 25, 2013 9:20 am ]
Post subject:  Easy Power Printing
Has anyone had problems printing the Arc Flash report to Adobe PDF? This locks up my computer.
Author:  wbd [ Mon Feb 25, 2013 4:26 pm ]
Perhaps some more details of what you are doing would help. I just tried to print a quick database report and had no problem. I picked Adobe pdf as my printer from the drop down box. I am running the following:
Windows 7 Professional 64 bit system
EasyPower Version 9.0.4.488
Adobe Acrobat X Version 10.1.5
Dell Latitude E6430, Intel Core i7-3520M 3rd Gen Processor, 6GB memory
Author:  Tim O [ Tue Feb 26, 2013 4:29 am ]
Adobe Acrobat X Version 10.1.6
I can print drawings data repoert ect. The only file I can not print is the Arc Flash Report.
Author:  wbd [ Tue Feb 26, 2013 2:39 pm ]
Yep, I just tried it and it locked up my machine. Have you reported it to EasyPower? You can open the report with Excel function and then print a pdf from that.
Author:  TJJ [ Mon Mar 04, 2013 7:11 am ]
Try updating your Adobe pdf software. Let me know if this works.
Author:  Tim O [ Mon Mar 04, 2013 8:02 am ]
Updated to latest Adobe and no difference.
Author:  TJJ [ Mon Mar 04, 2013 8:08 am ]
You may have to report this to EasyPower. They have a great support link on their website.
Good luck!
Author:  wilhendrix [ Mon Dec 30, 2013 9:41 am ]
I had the same experience using Easy Power (with other pdf software) if trying to print a one line. I'm currently using Easy Power version 9.0.4.501 and have not had any serious issues with this version.
When I was having problems, I checked with EZ power tech support. They asked me to use Adobe instead of the PDF creator I was using. I switched to Adobe, but still had the "easy power has stopped working" messages.
I called tech support and Pete helped me. He had me reload the software and that seemed to slow the problem, but did not 100% fix it.
I also had EZ power lock up when trying to print a one line with a logo attached. It turned out that I had TIFF file instead of a JPG (at least that's what I recall). I substituted a JPG file and that fixed it.
I use either Adobe or PDF viewer Plus by Nuance as well and both seem to work okay. Good luck!
Author:  wbd [ Mon Dec 30, 2013 10:51 am ]
I use Primo PDF for printing large format one lines from EasyPower. Haven'nt had any issues with that. I use it as the Adobe PDF printer does not support A1 size drawings.
