Conversion error in CSA Z462-08 Annex D?
Discussion in 'CSA Z462 Workplace Electrical Safety' started by Vincent B., Mar 4, 2009.
  1. Vincent B. Well-Known Member
    Hello there,
    In equation D.5.2(a) of Annex D of CSA Z462-08, the exponent of D_A is -0.9246. In equation D.5.1(a) of Annex D of NFPA 70E 2009, it's -1.9593. The two following sample calculations give the same Incident Energy given the same input data.
    All this seem OK, until you try some other value of D_A with both equations. Then you don't get the same results.
    Somebody fuddled with the exponent of D_A so the sample calculation worked out OK, but you can't do that as all other values of D_A won't give you the same results.
    I propose the following to replace equation D.5.2(a) of Annex D of CSA Z462-08:
    E_MA = 5271 x 25.4^1.9593 x D_A^-1.9593 x t_A x [0.0016F^2 - 0.0076F + 0.8938]
    which could be simplified in
    E_MA = 2981000 x D_A^-1.9593 x t_A x [0.0016F^2 - 0.0076F + 0.8938]
    Also, in CSA Z462-08, the definition of D_A for equation D.5.2(a) says it's in inch, when it should be in mm.
    The same conversion mistake has been made in equation D.5.3(a) of CSA Z462-08. I propose the following to replace equation D.5.3(a) of Annex D of CSA Z462-08 (once simplified):
    E_MB = 587460 x D_A^-1.4378 x t_A x [0.0093F^2 - 0.3453F + 5.9675]
    Any comments on this?
    To who should I report this?
  2. Vincent B. Well-Known Member
    A typo this time...
    In D.7.3 of Annex D of CSA Z462-08, the definition for K says:
    In D.7.2 of Annex D of NFPA 70E 2009, the same definitions for K says:
    I don't have IEEE 1584 to compare what that standard says.
    Thanks.
  3. stevenal Well-Known Member
    1584 agrees with 70E.
  4. Vincent B. Well-Known Member
    So CSA Z462-08 is in need of a correction.
    I'll look into how to do this.
  5. Terry Becker Member
    Vincent:
    I am on the CSA Z462 Technical Committee, next meeting is in Regina, April 1-2.
    We are treating all comments as formal requests for clarification, we need this to happen.
    Can you email me your comments so I can follow up formally
    Regards;
    Terry Becker
    www.esps.ca
    terry.becker@espsi.ca
  6. Vincent B. Well-Known Member
    Sure Terry. I'll do it so we get a better CSA Z462 in the end, one we can trust.
