Question on a size of Arc Flash
Discussion in 'General Discussion' started by Willis, Feb 19, 2009.
  1. Willis New Member
    Does anyone know what the results would be from a simple small distribution disconnect if it were short circuited and it had an arc flash. How large and destructive of an arc flash could this small of a device actually create?
  2. Zog Well-Known Member
    Depends on the available fault current and the clearing time of the protective device. Could potentially be a devesating arc flash that can destroy the equipment and injure persons anywhere in the room, or could be very minor and not dangerous, all depends on the factors involved.
  3. Noah Member
    For small disconnect switch, sometime it is hard to find space on the switch to put a lable on. How do you guys deal with those devices? What if you have a row switches on the wall for pump/motor control?
  4. Willis New Member
    Clearing time
    What do you mean "clearing time"?
  5. Zog Well-Known Member
    How long it takes the fuse or breaker to clear the fault at different fault current levels.
  6. Willis New Member
    Thanks!
    I appreciate the information Zog.
  7. Zog Well-Known Member
    Welcome to the forum.
  8. WDeanN Well-Known Member
    How small is a small disconnect? If its fed by < 30A molded case breaker, it is likely to be < 4 cal/cm.
    If it's fed by a 600A drawout breaker at a unit substation, it could be > 40 cal.
    We actually have a case like this, where the breaker is used to feed several things, including a 70A 480V welding receptacle that is now >40 cal because they chose to feed it directly from the UnitSub.
    Noah, if there is a wire trough above the disconnect rack, I would consider putting the label there, although I have also covered the factory markings at times (I do my best not to, though.)
  9. Willis New Member
    What is the cal/cm range that an arc flash becomes deadly or cause serious injury?
  10. Zog Well-Known Member
    1.2 cal/cm2 will cause second degree burns in 1/10th of a second. Put you in a burn unit, life changing event.
